19-02-2020 09:21 PM
My Sonos Play One won't connect to my EE router, either wirelessly or via ethernet.
Anyone have any tips, please?
19-02-2020 10:28 PM
I can't understand how it won't even connect via ethernet, there's gotta be something really simple in the settings.
19-02-2020 10:37 PM
Tell me what a Sonos is.
19-02-2020 10:41 PM
It's a wireless speaker system.
19-02-2020 10:49 PM
Like an Amazon Echo? There should be no issues with those.
19-02-2020 10:52 PM
On the router, I can see the sonos is connected with ethernet and it has a mac address and IP address but the status is 'not connected'.
19-02-2020 10:53 PM
Sonos is the daddy of wireless speakers, it was here 15 years before Alexa!😁
19-02-2020 11:02 PM
Show me that My Network page for the Sonos.
19-02-2020 11:17 PM
How?
19-02-2020 11:18 PM
Use the Camera icon above your text to upload a file to here.
24-01-2022 11:06 PM
Hi Hi. If it's first gen sonos and needs a zp100 to work then you are unlucky. New sonos don't need this and should work. for an older Sonos play 1, put the zp100 to one side. Plug an ethernet into the router and run it straight into the back of the ee smart hub. It should then work fine. don't plug in the zp100 as it will disconnect the broadband.
thus ..you can get the old play 1 to work, but only when hard wired to the smart (" dumb ") hub.
Not a great work around but it will work...just need a 10m ethernet cable and some gaffa tape.
Hope this helps.
If you found a wireless workaround, please let me know
