27-07-2022 10:50 PM
Hi Guys,
I have purchased a TP-Link AX5400 ArcherAX72 so i can benefit from WI-FI 6 and slightly better download speeds. However, I’m not too sure if i have set up both the Smart Hub (SH) and theTP-Link AX5400 correctly?
I have simply turned the WI-FI off on the SH and connected the AX5400 to the SH via the WAN port. In the AX5400 Settings i have chosen to be a “Access Point”. I have internet access with this set up. However, when testing both Routers i seem to only get around 55 mbps. My EE contract says i should be getting over 65mbps. I’m on fibre plus and right next to a BT exchange, so would have thought that my speeds would have been at the higher end of what i was supposed to be getting. I was hoping the the AX5400 would boost my download speed, but it hasn’t? I have read many reviews and it seems that most users see a increase in mbps download speeds using the AX5400. This leads me to think I haven’t set it up correctly with the SH?
Any help would be great. I’m not that good with setting up networks, so any help would need to be in simple terms.
27-07-2022 11:25 PM
Hi @SpaddyWaddy from what you have said, it sounds like you have set things uo right and getting speeds I would expect.
Whilst Wi-Fi 6 is great, it will not get you any faster speeds.
It would help if you could post the results after putting your phone number in the BTW DSL checker. That way we can see what your expected and actual sync speeds are.
27-07-2022 11:34 PM
Here’s what I’m seeing when I enter in my details?
27-07-2022 11:43 PM - edited 27-07-2022 11:45 PM
Alas using the address checker does not give as accurate results, and does not show your actual speeds.
PS make sure you don't include personal info like the phone number on the pic.
28-07-2022 12:45 AM - edited 28-07-2022 12:46 AM
Whose WAN port? It should be SH's LAN to TP-Link's WAN.
as the sync speed seen by the EE SH. I would imagine that you are getting the 55 Meg from WiFi devices connected to the TP-Link. That isn't what ISPs measure & quote, WiFi is unpredictable & unreliable and WiFi 6 won't make it any faster.
