Smart Hub Pro - DMZ not routing when accessed internally.
Toliver182
Setup described below.
All Cat 7 cable
ONT > Smart Hub Pro > TL-SX1008 (10GB 8 port switch) > PC with TP-Link TX401  ( 10GB NIC)
I have the PC setup with a static ip of 192.168.1.60
I have the DMZ selected at 192.168.1.60
I have also explicitly port forwarded ports 80,443 to 192.168.1.60
I have an external Cloudflare DDNS configured and managed by the PC (Not the router).
Lets assume my external domain is mydomain.com
I cannot access mydomain.com from inside my network on any other device, wifi or wired.
If i disable my wifi and go via mobile data i can access mydomain.com
I have also tested the following:
ONT > Smart Hub Pro > PC with TP-Link TX401  ( 10GB NIC) - No issue, this works
ONT > Smart Hub Pro > Smart Wifi Plus > PC with TP-Link TX401  ( 10GB NIC) - This does not work.
It appears the Smart Hub Pro struggles routing a DMZ via either a switch or Smart Wifi Plus.
Any suggestions? Is there a place where I can file an actual bug report?
0 REPLIES 0
