30-11-2026 11:35 AM
Apologies for the second post on the Smart Hub 7 Pro, which I’ve just received ahead of an Openreach install on Wednesday. EE have emailed and texted me to say I need to set up my hub before the install. For the life of me I can’t work out how to do this before the modem is installed - the 7 Pro doesn’t have the old grey broadband connection which I have on my current hub and FTTC service! Have I lost the plot here, or has EE?
30-11-2026 11:41 AM - edited 30-11-2026 11:51 AM
You don't, indeed can't, connect it to any BB but you could set up your preferred SSIDs & pwds in advance. Login to your EE Smart Hub/Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router. Then on the Advanced > Advanced Wireless page you should be able to see your WiFi SSID & password in clear & change them if you like.
Really, there's no need to even do that as the 1st time you link router to EE app, it'll give you the option to copy those settings from old router.
30-11-2026 11:52 AM
@CheshireCat59 : I just edited my post. I plonked a sentence in the wrong place so it didn't really follow.
30-11-2026 12:03 PM
Thank you for your replies, much appreciated!
30-11-2026 12:04 PM - edited 30-11-2026 12:11 PM
@CheshireCat59 The EE Smart Hub 7 Pro is a connected FTTP by Ethernet cable only to an ONT that you are having installed on Wed, setting it up ahead off schedule in your case can be challenging it does not have a VDSL modem stage and therefore CANNOT be connected as such to your old FTTC connection.
If you wish to do so then really suggest you park it standalone and connect via an Ethernet Device ie a PC/Laptop and direct Ethernet connection to the one off Lan port's on the EE 7Pro hub, match all the details for your current Hub, ie the SSID, wifi Password and the Admin password, then set anything else you feel. The 7 Pro should connect and go through a few routines with EE when connected on Wed after the Engineer has installed your FTTP connection, and ideally it FW updates to the latest and greatest that EE has, and your current devices in the Home auto connect, that is NOT a guarantee but will give you the best chance off up and running out the get go... If not wait and use the EE App method assuming you have one that is working. Last 3 FW's linked below have NO Idea what your current OOB version would be.
https://192.168.1.254 to web interface to the NEW EE hub.
FW: r4.29.1-R-1930437-PROD-1 and the gui is at App Version 3.14.5 27/07/2026
FW: r5.16.1-R-2011329-PROD-1 and the gui is at App Version 3.17.5 20/08/2026
FW: r5.16.3-R-2091196-PROD-1 and the gui is at App Version 3.17.5 12/11/2026
EE Smart Hub 7 Pro | Device Help
and if you got one also below this.
EE WiFi Extender 7 Pro | Device Help
30-11-2026 12:04 PM
30-11-2026 12:08 PM
Thank you! I’m going to wait until the ONT is installed and then take things from there.
30-11-2026 12:09 PM
Probably best!
30-11-2026 12:26 PM
@CheshireCat59 Just be 100% when you do it all 7Pro connected that you keep your old EE Hub powered up and disconnected from the old FTTC connection, hopefully OR takes care off the FTTC/FTTP transition BB wise should be no problem and Landline DV connection is JUST NOT instant swap so it can take 24-48hrs for that to gel together.
Carefully watch and double read the EE App step by step swap, it will help guide, if a device does NOT connect when it has all settled DO NOT go and start messing, just power it off, give it a couple mins and power back on again. Then see if it does so.
Your system is in for a shock going way up to wifi7 so DO THINK about were your OLD hub is now to were the OR/Contractor is going to wish to Plonk your ONT, one badly placed EE 7 Pro hub and you are going to be toast, smart wireless can only cut so much it is not a miracle worker.
30-11-2026 12:41 PM
Many thanks, this is very helpful to know ahead of the install!
