My broadband keeps freezing, im not happy im paying to high now too
Soulgirl101
Think I'm going to move to a different provider
@Soulgirl101   Are you eligible to upgrade?  You get better deals if you’re in contact.
@Soulgirl101 : Welcome to EE's Home Broadband Forum.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
