25-12-2021 06:42 PM
25-12-2021 06:56 PM
Is it the BB as a whole dropping or just the WiFi connections? Do Ethernet connected devices stay working? What colours are the light sequence when it happens? Your log does not show any BB discons. Is the device (IP=192.168.1.247) connected by WiFi & what is it?
29-12-2021 11:14 AM
it is the whole Broadband both wired and wireless connections.
29-12-2021 11:37 AM
29-12-2021 11:43 AM
Now im in the future 🙂
29-12-2021 06:23 PM
12-01-2022 04:49 PM - edited 12-01-2022 05:01 PM
Hi @JHG ,
I'm aware that your intermittent internet issue is somewhat dated now.
Did it resolve itself?
I've just noticed there are similarities with https://community.ee.co.uk/t5/Broadband-home-phone/Fibre-Max-Broadband-disconnecting-multiple-times-...
19:34:17, 23 Jun.CWMP: Server URL: https://arcadyan.x.x; Connecting as user: ACS username
19:34:17, 23 Jun.CWMP: Session start now, server: https://arcadyan.x.x, Event code:
19:34:16, 23 Jun.CWMP: Initializing transaction for event code 1 BOOT
19:34:15, 23 Jun.Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->9308,internal ports: 9308, internal client: 192.168.1.64
From a number of forum threads, the drop is proceeded by lines similar to those you have reported. The time discontinuity is obviously as the device has just rebooted and the time is the beginning of the epoch (so far in the past, not the future) which will be corrected when the router contacts a time server.
18:23:47, 25 Dec.CWMP: Server URL: https://ee.x.x; Connecting as user: ACS username18:23:47, 25 Dec.CWMP: Session start now, server: https://ee.x.x, Event code:
18:23:47, 25 Dec.CWMP: Initializing transaction for event code 1 BOOT
18:23:45, 25 Dec.DHCP device Disconnected: 192.168.1.199, f2:5a:20:fe:78:bf, Pixel-6
18:23:42, 25 Dec.Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->56150,internal ports: 56150, internal client: 192.168.1.180
Here is one with DDNS lines before UPnP lines but disabling UPnP resolved that one quite unexpectedly:
Here is something similar still under investigation and I'm hoping logs will be reported: https://community.ee.co.uk/t5/Broadband-home-phone/EE-router-random-restarting-I-can-t-contact-suppo...
Here is another example of essentially the same as reported, even down to the epoch reset: https://community.ee.co.uk/t5/Broadband-home-phone/router-disconnecting/td-p/856168
00:00:43, 01 Jan.Hub has activated against the device management system00:00:43, 01 Jan.Hub has activated against the device management system00:00:43, 01 Jan.WAN Auto-sensing last connection port: DSL WAN18:36:32, 21 Jan.DHCP device Disconnected: 192.168.1.160, 1c:c6:3c:76:2a:cc, WIN-IRGRIJ5EEVN18:36:26, 21 Jan.2.4G Client disassociate from 1c:c6:3c:76:2a:cc (IP=192.168.1.160) RSSI=0, Rate=0Mbps18:35:45, 21 Jan.Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->22229,internal ports: 22229, internal client: 192.168.1.16018:35:45, 21 Jan.Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->22228,internal ports: 22228, internal client: 192.168.1.160
18:35:45, 21 Jan.Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->22227,internal ports: 22227, internal client: 192.168.1.16018:35:45, 21 Jan.Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->22226,internal ports: 22226, internal client: 192.168.1.160
12-01-2022 04:59 PM
@mikeliuk the purpose of the forum is to help customers, not scaremonger or speculate on unconnected cases.
If you had any knowledge of routers you would be aware that there are a limited number messages reported by routers and the same ones will be shown when a line goes down.
