08-04-2022 12:58 AM
Hi. My interenet IP address is telling me im in the US. I definitely live in the UK. This is stopping me from playing some of online games etc. I contacted EE who told me it is something i have downloaded, which i know i havent. I have contacted the site i play on and they can clearly see i am from the UK. upto 24hrs ago i could play them with no problems at all. My internet connection was lost for 20 mins 2 nights ago , when it came back on my IP address had changed. can anyone help or explain how this can be?. many thanks Debbie
08-04-2022 01:32 AM
What device are you using to play games on? Do you have a VPN enabled?
If you are using an iPhone do you have private relay enabled?
08-04-2022 01:35 AM
The geolocation of public IPs isn't always accurate & often locates them at the place where they were 1st registered & not where they are currently being used.
What is the 1st 3 parts, out of 4, of your public IP that is mis-locating you?
All you can do is resync your router a few times, but not too often, to try & get a more acceptable public IP.
08-04-2022 12:14 PM
Hi. I'm using my PC. I have downloaded nothing since before Xmas. Everything was working A1 until Internet cut out, came back on 20 mins later and IP had changed. Same on my Samsung phone...can't play on that either, same problem. Thank you.
08-04-2022 03:29 PM
46.69.245.
09-04-2022 11:28 AM
If you google whats my IP what does it say your location is UK?
09-04-2022 05:05 PM
09-04-2022 09:15 PM
Very strange this doesn’t happen unless there is something locally putting you there. This normally vpn or virus, botnet.
The other possibility whoever had this ip before was running some service which put them in USA and they still have that ip associated with that service and they haven’t updated it to their new ip.
I would unplug your router leave it for maybe 30 minutes and plug it back in.
09-04-2022 10:57 PM
California. Mountain View, nice, what's the Weather like out there.
09-04-2022 11:07 PM
