09-09-2022 07:07 PM
I am having constant problems with my broadband dropping out over the past week. The solid aqua on the front turns to a flashing yellow and all connection is lost. It then reconnects after around 5 minutes.
Is this common issue or is there anything I can do to fix it?
09-09-2022 07:12 PM
09-09-2022 08:04 PM
1.
Product name,EE Smart Hub
Serial number,+EEH001+2113005787
Firmware version,v0.06.01.08190-EE (Wed Aug 19 18:20:33 2020)
Board version,01
Data sent / received,6.3 MB / 49.2 MB
DSL uptime,0 days 0 Hours 1 Mins 46 Secs
Data rate,4.34 Mbps/46.33 Mbps
Maximum Data rate,4.3 Mbps/53.0 Mbps
Noise margin (up/down),5.9/7.7
Line attenuation (up/down),31.1/30.5
Signal attenuation (up/down),28.5/30.6
Broadband username,PRODUCTIONHQNUNXXXXXXXXX@fs
2.4 GHz wireless network name,2.4GHz-EE-Hub-SkXL
2.4 GHz wireless channel,Smart (Channel 1)
5 GHz wireless network name,5GHz-EE-Hub-SkXL
5 GHz wireless channel,Smart (Channel 48)
Wireless Security,WPA
Wireless mode,Mode 1
Firewall,Default
MAC address,8C:19:B5:43:20:41
Software variant,-
Boot loader, 0.0.3-EE (Mon Dec 4 17:32:53 2017)
2.
https://www.thinkbroadband.com/_assets/speedtest/button/1662749611182055055.png
3.
| 80 | 71.1 | 20 | 19 | 65 | Available | Available |
| 80 | 67 | 20 | 19 | 60 | Available | Available |
| 330 | 50 | -- | Available | -- |
| Up to 17 | -- | 10 to 19.5 | Available |
| Up to 17 | Up to 1.5 | 10 to 19.5 | Available |
| Up to 7.5 | -- | 6.5 to 8 | Available |
| 2 | -- | -- | Available |
| Available |
| Available |
| N |
| N |
| Y |
09-09-2022 08:51 PM
Seems rather slower than expected.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
