close
S10e android 11 boot menu
Mattri
Hi
My phone is sluggish after updating to android 11 ui 3.0. I want to delete the cache partition but I can't work out how to boot to the menu to allow this? I've tried suggestions online but none seem to work. Thanks.
WOZ140
Hi, @Mattri,
I had a similar problem when my Galaxy S20 updated
to Android 11. My solution was to do the same procedure
with the phone connected to a charger or PC USB port.
I should imagine It'll work on the S10, give it a try.
James_B
EE Community Manager
Hi @Mattri,
What have you tried so far?
WOZ140
Hi, @Mattri,
Brilliant, thanks. Worked when plugged into laptop (didn't work with charger).
