13-03-2021 07:17 PM
Have not used my SIM for just over 6 months due to Covid, how do I get it put of hibernation?
13-03-2021 07:27 PM
I have just noticed, that the SIM card used data I'm the last 20 days. So it should still be active - correct?
I use this SIM in a tracker connected to my car, so each time it moves it sends data.
I logged onto my account and thought it may need topping up, so I have just stuck a fiver on it, but it is still not working. To test the sim I put the card into a different phone and it is unable to send or receive texts? My app is saying there is £7 in and also it has 9MB left?
Any suggestions?
13-03-2021 08:32 PM
No, @Po0oley, it is not using data that keeps it out of hibernation but the actual moment of buying of the data in the form of a pack or add-on.
To get it out of hibernation after 6 months of non-chargeable use, you need to phone CS.
13-03-2021 08:58 PM
What times are they open?
Also, I have just found the last text I sent on the device, it was 27th August 2020, so 198 days, and it is showing that it went off almost 19 days ago. So this is the problem.
I have just stuck a fiver on it so I hoe I don't loose that.🙂
13-03-2021 09:10 PM
Yes, you've passed the 179 days since you last spent money on it.
CS is open most days 8am to 9pm. Closes 8pm on weekends.
13-03-2021 09:26 PM
Many thanks. I now know the reason,I will call them tomorrow to fix the issue and then stick a reminder to send a text every couple of months to keep it going
16-03-2021 09:46 AM
This has not actually fixed the problem, CS are saying the SIM card is now unblocked but I am still unable to use it. I have transferred the SIM into a phone and it still does now work, I try to send a text and the phone is saying 'operator determined barring'
I don't know what else to do now?
16-03-2021 09:49 AM - edited 16-03-2021 09:50 AM
16-03-2021 12:05 PM
I am in the UK,
16-03-2021 12:36 PM
