close
How to extend WiFi to summer house in the garden
Beckishaw
Hi
I have a summer house in the garden which is about 10 metres away from the house I need to use for an office but the WiFi signal doesn’t seem to be very good from the house .
I have a booster but doesn’t seem to do the job very well.
Is there anything more I can do ?
Does the summer house have a mains supply from the house on the same distribution fuse? If so, you could use Powerline Adapters.
Will the EE booster plug connect my WiFi to my summer house? It has power going straight from a source in my kitchen
If your planning on using this as an Office location, thre way I would do it is to run a Secondary Cat 5e cable(s) from the existing Router location to the Summer House then use a Second Router.
It's not the easiest way forward but is certainly the best way forward for a reliable Work Environment.
