18-11-2020 02:57 PM
I have tried to download the Boots advantage card from Play store but I get a message that states this software is not available in your country.
This phone is part of a package I got from one of your stores.
18-11-2020 03:04 PM
Hi @kuma
Are you able to download any other apps ok, or is the problem specific to this Boots one?
18-11-2020 03:11 PM
Yes I can download other apps
18-11-2020 03:22 PM
If I try to find the app in Play store it does not appear. I have to go through Boots website before I can get it to show in Play store.
18-11-2020 03:51 PM - edited 18-11-2020 05:27 PM
Hi @kuma
Have you downloaded the Boots app, from the Play Store?
I have just checked this app and you can add your Advantage Card on the Boots app.
Thanks.
