10-05-2022 12:15 PM
Can you tell me how much it costs to replace an iPhone 6 screen that is smashed?
10-05-2022 12:22 PM
~£150 if you take it to Apple out of warranty.
Independent repair shop will do it for less if you can find one.
Have you considered a newer iPhone as a replacement? The 6 no longer receives updates, so a refurbished 6s or 7 might be worth considering. Just food for thought!
10-05-2022 02:17 PM
10-05-2022 03:05 PM - edited 10-05-2022 03:06 PM
@VickyP11 While an independent repair shop can do it for less it will not be a genuine Apple screen. If that independent repair shop is Apple approved they will charge the same amount as Apple will.
Just depends on what you want to pay.
