Phone repair
Hunter8991
I have an iPhone 14 Pro Max, the back glass is smashed and the left side of the phone is buldging out from the screen (battery replacement needed) as I need the battery replacing will ee sort my battery out without having to sort out the back glass
8 REPLIES 8
Christopher_G
Hi @Hunter8991
Welcome to the community.
I'm sorry to hear about your phone. Do you have insurance for it or are you looking to pay for a repair?
I don’t have insurance on the device but to repair the battery is around £70 I am looking to pay for that
Sent from Outlook for iOS<>
Christopher_G
I'm not sure we'd be able to replace the battery if the phone is damaged like that, @Hunter8991
If you speak to our Mobile Care team, they'll be able to look into this for you.
I can’t mange to get In contact with anyone.  I’ve tried ringing the ee store I’m meant to be visiting in a couple of days but as soon as the automated voice message finishes it cuts off the call imminently,   The back isn’t very badly smashes it’s more cracked than anything
Christopher_G
Ah OK, thanks @Hunter8991
They'll be able to inspect it when you go in and run through your options with you. Hope you get sorted.
@Hunter8991  They will repair all faults.    The back glass could break more and then you’ll want that fixed for nothing as it has more damage. .     Apple will do exactly the same as would any other repair company.    They wouldn’t undertake this unless all faults are fixed.
Will youse replace an iPhone screen that’s been replaced with an aftermarket screen?
Peter_W
Good afternoon @Nisbot, welcome to the EE Community.
Screen repairs will always be outside of your handset warranty, but usually it's dependent on the overall condition of the handset for whether a repair is possible.
It's always best to get this checked by a technician in person so we can be 100% sure, so to find details of your nearest branch with in-store repairs, please check out our store finder here 😊
Peter
