23-01-2022 08:20 AM
Are there any instructions on how to set up conditional call forwarding/conditional call divert on iPhone?
once it’s activated by EE, apparently on Android phones you can easily set this up.
On iPhones the phone does not have any settings to allow conditional call forwarding to be set up.
tech support are clueless and cannot help! One tech support advisor claimed there’s no such thing as conditional call forwarding!!!
23-01-2022 09:41 AM
Hello @Wired123
There's no instructions on the EE website as far as I know, but https://www.geckobeach.com/cellular/secrets/gsmcodes.php is as good as any independent webpage for this.
If not, a Google search for "GSM codes call divert" should find several suitable pages.
23-01-2022 11:16 AM
thanks pal, you would think EE tech support would be able to give some official guidance on this rather than bury their heads in the sand and force us to go to a third party source.
annoying Apple don't have this feature built into the software, given I had these options on my Noka and Ericssons in the late 90s!
