29-01-2022 04:34 PM
I have Galaxy S10 phone with two Emei numbers.
When trying to unlock the phone, which do I use, or do I have to unlock both numbers ?
Any help appreciated.
29-01-2022 04:53 PM
@Tonybrightntl you use the one for the physical SIM card slot. This will unlock both slots as your unlocking the device not the actual slot that the IMEI is for.
30-01-2022 07:48 AM
But which number is for the physical SIM card slot, number 1 or 2 ?
30-01-2022 09:47 AM
Morning @Tonybrightntl
Have you checked checked if your device is unlocked online?
If two IMEIs show up - your device is probably unlocked already, if you can try both IMEI's to see if this is unlocked for you.
