16-05-2022 05:47 PM
How do I scan the QR code that Amazon sent me for a parcel return?
16-05-2022 09:47 PM
Can't you just connect your mobile by WiFi to the home router that your PC is running over & just use its data?
16-05-2022 10:02 PM - edited 16-05-2022 10:02 PM
I have no idea how - I have never had a smart phone before so I don't know any of this stuff and I can't find anything on YouTube that explains it. They all assume a great deal of background knowledge which I don't have. I do have a USB cable that can plug the phone into the PC
16-05-2022 10:14 PM
On the mobile go to somewhere like Settings > Connections > WiFi. Enable WiFi if it is OFF. Click on it & you'll see a list of WiFi networks in range. Look for your router's network SSID(s). Choose stronger 1 of those & supply the router's WiFi pwd or key which you should find on a label on the router.
I don't think USB gives you access to Net.
16-05-2022 11:46 PM
Thanks very much! That worked, and I now have the web on my phone. Now I need to figure out how to find and download the QR scan app
17-05-2022 12:47 AM - edited 17-05-2022 12:49 AM
Thanks! You're welcome 🙂 ! Glad I could be of assistance & that's now sorted.
Your phone should have an appstore app on it, probably Google PlayStore or Apple iStore.
What you gonna do with the QR code once you've scanned it since you have no printer?
17-05-2022 08:14 AM
Hi @NorthTower.
Have a look at our Pay As You Go Packs Help Page for more information on what our packs offer, and how to add them.
Jon
