28-02-2022 08:28 PM - edited 28-02-2022 08:30 PM
Recently bought a reconditioned S20FE and almost immediately had problems with it maintaining a connection to the EE network.
It has a perfect connection in certain places (including home which is good) but will often lose connection when I'm out and the phone can't make calls or use 4g.
Reading around the subject, I've tried
- Reset network settings
- A new SIM card
- Putting sim into slot 2 (better but not much)
- Speaking to EE
- Manually selecting mobile network
- Rebooting phone
Nothing really seems to help. I wonder if it's software, fault with the handset? I've checked with EE and doesn't seem to be coverage related
28-02-2022 08:45 PM
@W_8 Try a factory reset and if that does let work I would call customer services about this as I could be a faulty device.
28-02-2022 08:58 PM
Thanks, I forgot to say I tried factory reset too 🤣. Think I may have to accept a faulty device
03-03-2022 10:24 AM
Posting a comment as per suggestion in EE email...
If you didn't find the perfect answer, please post a comment to let us know. It's likely that other customers, such as our Community Stars, will help you out. If they can't help, a member of the EE Community Team will.
03-03-2022 11:41 AM
Hi @W_8,
Have you checked the coverage map and network status checker for the areas where you are experiencing problems?
03-03-2022 12:09 PM
03-03-2022 12:13 PM
03-03-2022 12:19 PM
It's a reconditioned model.
How would I tell if it's a UK model?
03-03-2022 12:36 PM
03-03-2022 12:46 PM
