17-05-2022 01:26 PM
An update has been posted on repair tracking.
The device needs to be exchanged and the swap device has been requested
What does this mean...
17-05-2022 01:29 PM - edited 17-05-2022 01:30 PM
@BigB111 The device that has been sent into repair is going to be exchange for a different device. It’s probably beyond economical repair or can not be repaired so you’ll get back a different device that’s the same model of the same specs.
17-05-2022 02:34 PM
Thanks for the reply. Do you know how long it would typically take for a replacement device. Also do they have to tell me if the replacement device is a refurbished one.
17-05-2022 03:25 PM
Hi there @BigB111
The repair centre should be in touch to go through everything with you.
If you would like an update please give us a call on 150, and the team will get this looked into for you.
Leanne 🙂
17-05-2022 04:35 PM
No they don't have to tell you as they would have in the T&Cs already.
It will be a refurbished device unless you purchased very recently.
30-05-2022 08:48 AM
Hi my A52 has just suddenly become unresponsive on the touch screen and I can't unlock the phone or get into it. Can you please let me know what the process is for sending it into repair.
30-05-2022 10:06 AM
Hi @12111968,
Please see Book a phone repair for everything you need to know.
Hope this helps.
