Does Pixel 6 Pro support WiFi calling with EE?
neilcooper33
Hi all...
Does Pixel 6 Pro support WiFi calling with EE?  I'm currently with Spusu who run off the EE network and i've realised that they don't support it.
Thinking of changing to EE if they do support it.
thanks
Neil
@neilcooper33   That device is right HERE  and you’ll find that right HERE   Just do a search on that page.
@neilcooper33  Yes.    WiFi calling is included with all EE sims,  contract or PAYG and if your device supports WiFi calling then you’ll get it. You’ll also be able to text via the service its not just for calls.
neilcooper33
ok, thanks... that's useful.
I used wifi calling on my phone when i was with o2 previously
But now i've changed to Spusu, they have said that although they do support Wifi calling, they don't support it on my phone (Google Pixel 6 Pro).
Do you know if there's a list of devices online which do support wifi calling on the EE network?  I've tried to find this online, but haven't had any luck.
thank you!
