31-01-2022 04:34 PM
I connected to my broadband last night and it was flagged as suspicious by Norton. I checked why and it said it was comprised by an attacker. I panicked and looked online as to what to do, I saw that I should change my admin password and the router password and factory reset the router. Should I have done this? Is there anything else I should do? I’m now really anxious to do anything on the internet. Many thanks.
31-01-2022 04:47 PM - edited 31-01-2022 04:58 PM
It's not your BB that's being reported as suspicious but a website you have visited via your BB. They won't have got hold of tour router's admin &/or WiFi pwd but to be safe you could changed these. Which router have you?
31-01-2022 04:54 PM
Ok, it just my Norton is telling to leave the network as it was comprised. I have changed the boxes passwords. I have an eye smart hub router.
31-01-2022 04:59 PM
OK, what is the exact full msg that Norton is giving you verbatim?
31-01-2022 05:04 PM
Hi @DeanC232 ,
Did you install the Norton software yourself, or did it come with the computer?
Have you used this Norton software for some time, or has it only recently appeared?
31-01-2022 05:10 PM
this is what comes up on the Norton app for both me and my partner.
31-01-2022 05:13 PM
No I downloaded this Norton subscription as part of my broadband package.
31-01-2022 05:13 PM
Hi @DeanC232 ,
From a quick google of "Norton suspicious compromised network", it's quite possible it's a false alarm.
If you believe it's a false alarm and you believe your home network can be trusted, you can take the steps at the below link.
Fix problems with Norton detecting a trusted network as a suspicious network
