13-04-2022 11:10 AM
Roaming is activated on my phone and in my account, and before I travelled to the USA I activated the Roam Further Pass by texting to 150 (and it does appear in my list of add-ons on the account). But now I'm in the USA and the phone has no signal and can't detect any networks.
Last time I travelled to the USA in December I was using the Travel Data Pass and I also had no signal for the entire trip, but now I'm paying £10 for a month of not getting anything I would like to please sort this out.
15-04-2022 12:46 PM
Thank you, @XRaySpeX . I was able to connect with someone over the internet, and it took a while but they resolved the issue and I now have data roaming working.
Not sure why it happened, but my wifi network was interfering with the scanning for mobile networks, both automatic and manual. Turn off the wifi, do the manual search, then turn wifi on again and it's all fixed.
13-04-2022 11:20 AM - edited 13-04-2022 11:22 AM
Hello @Supermorff ,
Welcome to the community,
Did you make sure that roaming,, call abroad and premium calls are activated in settings, which you can do via the My EE App or website by logging in to your Account? Just because you have the roam further pass or travel data pass, does not mean roaming is activated.
If you are unable to do this and you have Skype, you can ring customer service for free, you will find the free number by clicking on the contact us at the top of this page. Also, if you have not restarted your mobile, try that. You may also want to do a manual search for a network, T-Mobile should work, if I remember rightly, when I was there in 2019.
13-04-2022 11:26 AM - edited 13-04-2022 11:26 AM
Hi @Schockwave, thanks for the quick response.
As I said in my first post, roaming and call abroad are both activated in settings. (I'm not sure about Premium Calls or where that is or whether it's important?) I have restarted my phone several times, and my phone can't find any networks, whether EE or T-Mobile or otherwise.
When I was in the USA in 2019, my roaming worked fine using the same phone, but since I came back in December I get nothing.
13-04-2022 01:00 PM
Hi @Supermorff,
Is roaming still showing as active in My EE if you go to Menu > Account Settings > Parental and Data Controls?
Have you been able to test your phone in more than one location to rule out a local network issue?
13-04-2022 01:23 PM
Hi @James_B,
Thanks for the welcome.
Yes, roaming is still showing as active in MyEE.
I have tried the phone network in two locations, the airport (in a large city) and the resort where I'm staying (over a hundred miles away from the airport), as well as a little bit en route.
Something I've just noticed is that, in the 'Network and Internet' screen on my phone, under Calls and SMS it says 'EE (Temporarily unavailable)'. No explanation as to why, however.
13-04-2022 01:34 PM
@Supermorff Have you restarted the device since you got there ?
13-04-2022 02:08 PM
Hi @Chris_B,
Yes, I have restarted the device several times since arriving. I've done it again just now to make sure it's still the same, and yes it's still the same.
13-04-2022 02:19 PM
Hi @Supermorff,
You won't be able to connect to the EE network when outside the UK.
If you scan for networks manually, are you able to select T-Mobile?
iPhone - Settings > Mobile Data > Network Selection > Turn off Automatic
Android - Settings > More Networks > Mobile Networks > Network Operators > Tap OK
13-04-2022 02:24 PM
Hi @James_B,
When I unselect the option to find networks automatically, it takes me to a page headed 'Choose networks', loads for a while, then says 'No networks found.'
13-04-2022 03:47 PM - edited 13-04-2022 03:48 PM
Hi @Supermorff,
Please get in touch with Customer Care so our technical support team can run through some diagnostics with you.
They'll be happy to help.
