12-02-2021 03:49 PM
Hi there
I'm presently in Nigeria. I can receive text messages on my EE phone but can't make and receive calls and can't send text messages. I didn't opt for roaming before I left the UK.
when I try to make a all is says this number has been barred. But the network shows full strength and connected.
Please can anyone help.
12-02-2021 03:50 PM
I am on pay as you go FYI
12-02-2021 04:12 PM
Hello @Cmoorjani.
Welcome to the community.
Are you pay as you go or pay monthly?
Pay as you go roaming is automatically enabled.
Katie 🙂
12-02-2021 06:02 PM
Hi Katie,
I'm a pay as you go customer
12-02-2021 06:04 PM
Yes I understand but why does it say my number is barred when I try toncall out or try to call it from a local number
Thats what is confusing me.
12-02-2021 06:06 PM
Hi @Camoorjani.
Did you SIM work OK in the UK before you travelled abroad?
Katie.
12-02-2021 06:12 PM
Yes it did. It worked perfectly well. I just got to Nigeria on Tuesday.
13-02-2021 08:18 AM
Hi @Cmoorjani.
Are you able to try manually connecting to another network in Nigeria?
What phone are you using?
Jon
13-02-2021 08:59 AM
Yes I have but it does not connect. It only connects to 9Mobile automatically.
I'm using Samsung Galaxy tab s6 lite, but I also have tried it on my iPhone X, same issue.
13-02-2021 11:30 AM
Thanks @Cmoorjani.
If you change the network mode to manual, are you able to connect to the other network?
Jon
