13-05-2022 12:50 PM
I have the voicemail icon on all the time even if I don't have any messages. I get a pop up's that I have a message but when I check there is none. I have no idea how to fix that.
13-05-2022 12:48 PM
I must say EE website is one of the worst for help. I can't see a way to post, chat isn't on, no email address.
13-05-2022 01:18 PM
@pictureworld Call your phone from a different device and leave yourself a voicemail. Then from your iPhone listen to that voicemail in full then delete it. This should refresh your voicemail inbox so getting rid of the notification.
13-05-2022 01:21 PM
@pictureworld .. on my Samsung, I go into the phone app/keyboard, tap the 3 dots in the top right corner, choose settings then voicemail, notifications. Changes can be made there. If you have an iPhone I would guess there will be similar option.
On my previous phone I did used to get a stuck phone message icon after I had already listened to it. I think that was more of a phone quirk than anything to do with EE.
13-05-2022 05:43 PM
To remove a stuck voicemail icon, try calling yourself from another phone and leave a message.
Then call your voicemail and delete the message you've just left.
