14-01-2021 09:49 PM
Hey - thinking of upgrading to the S21 Ultra but need dual sim. Anyone able to tell me if the handsets EE sell in the UK will have dual (esim and nano)??
15-01-2021 09:25 AM
15-01-2021 09:31 AM
@mrdonmccann please bear in mind if you purchase from EE the phone is locked to EE and can't be unlocked for 6 months.
So if you need dual sim to use another network as well you won't be able to for the first 6 months.
22-01-2021 11:23 AM
Hi.
Can someone from EE confirm this is true please? I won't be able to use dual sim for the first 6 months if i buy a Samsung Galaxy S21 Ultra?
22-01-2021 11:24 AM
22-01-2021 12:18 PM
22-01-2021 01:02 PM
One sim will be my EE contract, the other my work vodafone SIM
22-01-2021 01:04 PM
Hi @urbine94.
Both SIMs would need to be EE SIMs for the first 6 months.
You can then process an unlock request.
Katie 🙂
22-01-2021 01:27 PM
Ok thanks. I'll just buy the phone outright and do sim only then instead.
06-03-2021 10:14 AM
Hi I got the
s21 ultra on release date I was wondering the same thing as I upgraded from the S20 ultra which I did have two numbers in I had an Esim sent out to replace my number and I was going to put a physical second number sim in the slot however I scanned the card QR code for the E sim it did not take come up with an error so still greyed out also asu can see got these errors when starting backup plus now shows data call text using SIM 1? When I went into my my SIM management they are greyed out can't you have two SIMs just spoke to EE they don't even have the diagnostics as yet so I would hold off as also told I have to have 2 EE numbers and not an alternative network ad can't not get my phone unlocked for 6-months hope this helps....EE rap if you're reading would love your feedback on this this
