23-04-2022 11:20 AM
Recently got a 5gee wifi and its working great but the lan port doesn't work correctly.
Plugged the lan port into my computer and I can connect to the 5gee box through the IP address (192.168.1.1) but there is no internet connection through the lan.
Through wifi everything works great.
23-04-2022 12:28 PM
Hi @MichaelAtko
Have you checked your connection on your pc network settings?
Have you tried flushing your pc DNS?
23-04-2022 12:45 PM
Just tried and still no luck.
23-04-2022 01:35 PM
Win10 ?, when you plugged the cable in for the first time did Windows prompt you or try and set up a New Connection?
23-04-2022 01:47 PM
Windows 11.
No it didn't prompt anything.
23-04-2022 02:52 PM
Hi @MichaelAtko
What does it say you are connected to under network and internet?
Also you are receiving a 5G signal?
