16-03-2024 07:34 PM
Lots of posts and frustration on this, so wondering if EE are making any progress at all?
If you are lucky enough to have it all working, perhaps you could share what you / tech support did to get it working.
18-03-2024 03:08 PM
Moved from BT 900 to EE 1.6Gbps today. Open reach came out and fitted the new ONT, took him less then 5 minutes, I use a third party router left it turned on, and did not reset it. Just got 1.2Gbps over WiFi 6E and averaging 1.7gbps with my wired connection (did briefly see 2Gbps)
18-03-2024 11:32 PM
Multiple sources were told by agents including me that an official fix is due to be rolled out on 25th for WiFi controls let’s hope this works otherwise there will be violence 😹
