17-12-2023 07:12 AM
Can someone please help, WiFi controls either don't show on app or they don't work.
WiFi enhancer does not load .
Setting groups or controls does not work, registered devices do not show.
Can't test speed.
25-12-2023 08:14 AM
All sorted after speaking to tech team, hub needed to be reset and uninstalled app. This was achieved with a BT/EE guide on the phone. You need to speak to tech team who will guide you through the steps while they do the magic in the background. Took a few days to sort very busy and helpful team.
Thank you.
17-12-2023 01:38 PM
Hi @5076 and thanks for the post.
Sorry you're having problems with the WiFi controls. I can help. Please check your inbox for my message and drop me over the details.
Cheers
David
17-12-2023 02:29 PM
The app is a mess at the moment. So many users are having issues. I've said it before in other posts, but I think we are all paying to be beta testers on the "new" EE products at the moment.
17-12-2023 03:21 PM
@5076 wrote:
Can't test speed.
Try a speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
18-12-2023 09:32 PM
Exact same situation. Really starting to 'P' me off. Considering cancelling and goin back to BT tbh. We've been sold an inadequate service.
18-12-2023 09:38 PM
Really starting to loose faith in EE. Wifi working, but can't control my WiFi as I'm 'not connected to WiFi network ' ????? Even though I'm ON IT NOW 🤬 ???? Tried speaking to EE support teams. Several for that matter. Complete waste of time. Reps just pass the case along to ' Technical team member ' . Seriously considering closing the account and goin back to BT. We've been sold an inadequate service. I'm not alone in this either by the looks. SHOCKING.
18-12-2023 09:41 PM
You're not alone. Absolute shambles since I switched from BT. Considering cancelling and goin back to BT. Their app was faultless.
19-12-2023 01:08 AM
Did anyone get this sorted 😔 I have tried everything I can think of. I’ve managed to connect the smart WiFi devices but like most of you I’m getting the message saying I’m not on my home network 😡
19-12-2023 01:17 AM
I have the same issue - can I get some help please?
Adrian
19-12-2023 08:49 AM
The only 'solution' I've found so far is not to use the app, but to manage the system using the router's management portal, accessed by entering it's IP address into a browser.
