18-01-2022 08:52 PM - edited 18-01-2022 08:57 PM
I've currently got an EE plan and linked my Galaxy Watch 4 LTE to it so get calls and texts from my mobile plan but uses it's own data plan and want to know if I purchased a sim for my Tab S6 can this do the same - ie have the data on its own plan and be linked to my mobile to get calls/texts or can you use a normal sim in the tablet without issues (so has own number, calls/texts/data in case of issues with the main phone).
And would I be able to get this new number on our discount perks we now get with ee
18-01-2022 09:03 PM
@walkerx No it’s not possible to link the tablet to your phone tariff like the watch. Does that tablet support calls/texts on EE ? It’s not advertised as it can. It can make calls/texts when you link it to your Samsung account that your phone is on. It’ll then use your phone/text allowance from your phone tariff.
18-01-2022 09:20 PM
@Chris_B It is the Tab S6 LTE 256GB version not the LITE version
I've tested with my Three Sim and it can make receive calls/texts through that so can't see why it wouldn't work with an EE sim.
19-01-2022 07:51 AM
19-01-2022 08:10 AM
@James_B thanks, but an EE normal sim should work in the tablet if wished to use this way seeing a three sim works.
Also if I cancel my contract with three (as I won't be renewing with them) when the contract ends, can i use the STAC against a PAYG SIM on EE.
19-01-2022 08:22 AM
@walkerx Yes an EE sim will work like your other sim
20-01-2022 11:42 AM
@Chris_B wrote:@walkerx Yes an EE sim will work like your other sim
Thanks,
If I took out a PAYG sim, can I use a STAC code on that? As the calling/text features on tablet will only be used for backup and calls/texts I don't want on main number.
Data wise it will only be a few weeks each year as most of other time it will use wifi (just had to keep current sim as it would have cost more than outstanding balance to cancel contract) so not looking at a full sim contract
