17-07-2023 10:03 PM
Over the last day or so the black edging round my phone has started to raise slightly then today I noticed it more then as I was using my phone when I got home from work just above where the crease is it's started to go black on the actual screen, I only took out the new contract in September last year, the phone still works fine ATM but I'm worried maybe the longer I leave it it will spread across the screen
18-07-2023 08:12 AM
Morning @JBBoden_1984
I would suggest getting in touch with our tech gurus on 150, they run some troubleshooting with you for the device to see what will be needed 🙂
Or, you can visit an EE Store to get the device looked at and discuss your options.
Hope this helps.
