04-05-2023 09:27 PM
Has anyone had any issues with Pixel 7 regarding data signal? I’m finding at times that my pixel is flicking to H or H+ then not able to go back to 4g/5g without resetting the network either turning it on/off or airplane mode on off.
I know there were issues with earlier pixels doing this including the Pixel 6, did they ever fix this?
05-05-2023 08:08 AM
Welcome to the community.
Do you notice this in one specific area? If so, pop your postcode into our network coverage checker and hit 'check status'.
06-05-2023 09:19 AM
Hi Chris
its not specific areas, I read something online about going into the settings and deactivating dual sim. Which is a bit annoying, but trying it. Just wondered if it’s come across from pixel 6 problems as that also had issues.
