Mobile Data
A place to ask questions and share tips about using mobile data.
Forum Posts
EE APN Settings: Where to find them
Hi there, For APN settings please see our dedicated Help page at https://ee.co.uk/help/mobile/fix-problem/Managing-APN-settings. This Help page will give you the link to download the correct APN settings for your device. It will also give you a step-...
Sean_D by Former EE Community Manager
  • 134010 Views
  • 49 replies
  • 20 Helpful
Roaming
I can't add on plan with data on abroad
djbeat69 by Investigator
  • 59 Views
  • 4 replies
  • 0 Helpful
Slow Internet speeds
Hello my internet speed is so slow, I checked on speed test as well, my internet is so slow.what should I do?
Sherzad by Contributor
  • 34 Views
  • 1 replies
  • 0 Helpful
Strange Data drop out
OK, here's a strange one that even the EE level 2 tech support are struggling with.At certain locations, mainly near my home, I have no data on both physical sim and eSim on my S22 Ultra.Other family members have data connection with EE with no probl...
Why is mobile Internet poor
Not sure if in correct place or not, but wanting to know why mobile data is so slow. Constantly apps won't load pages (even social media apps can't be used properly) , can't browse Internet properly, can't use vpn when needed (even in emergency for w...
walkerx by Skilled Contributor
  • 106 Views
  • 6 replies
  • 0 Helpful
Data
I have unlimited mobile data but now they say I have run out till 9th may?
