01-05-2024 09:48 AM
I have unlimited mobile data but now they say I have run out till 9th may?
01-05-2024 11:50 AM
Hi @dianelester
Welcome to the community.
What exactly did the message say? It's possible that it says you've used 100% of your giftable allowance. One of the rules for data gifting on an unlimited plan, is that you can only gift from the first 100GB of usage. If you don't use data gifting, you don't have to worry about that.
02-05-2024 01:03 PM
Hi thank you for replying
my bill says inlimited data
then you have used 105 of 105 resets on 9th may
last month i used 357 of 600
02-05-2024 02:37 PM
