20-04-2022 06:19 PM
Where Can I find my data usage?
I have 100gb of data but in less than 2weeks I have none and I haver not been streaming, why?
20-04-2022 06:25 PM
Hi @Steff7
The only place where the reason for data usage will be itemised, is on the device that used that data. Your EE account will only show you the amount of data that has been used.
If this is a phone, then the data connections menu will itemise usage down to individual apps. If it's a router, then only the device connected to that router will tell you.
