Unable to gift data
huxyboy
Since the new app has been installed I am unable to gift data without contacting customer services.  Help!  I use this to gift data to my son that is on the same account.
Leanne_T
Hi @huxyboy
Thanks for posting.
What happens when you try and gift data in the app?
Can you gift data using your My EE account online?
Thanks.
Hi, when I click on my mobile number and then attempt to select the number to receive the gifted data the drop down box does not work.
angiexcx23
Hi, I have the same issue. Have you figured out a solution yet? Thanks.
James_B
Hi @huxyboy and @angiexcx23,
An update which fixes the data gifting issue will be available soon. In the meantime, you can gift data via My EE online.
