15-04-2024 10:43 AM - edited 15-04-2024 10:47 AM
I gifted 2GB of data from one sim to another this morning and it is showing gifted from one but doesn’t appear on the other - I got no text.
tried again with 500MB and this time got a notification text but this also hasn’t appeared on the data allowance for the sim I gifted to.
Update: I don’t think it’s updating data for usage either on the SIM I gifted to as it still has the full amount from the start of the month.
15-04-2024 12:46 PM
@Pgallon311 : Is the SIM being gifted to in the UK?
15-04-2024 12:55 PM
Yes - it’s something I do every month as I have 25GB on one and only 500MB on the other which I have repurposed to use in a security camera.
15-04-2024 05:03 PM
Do your allowances update if you restart the EE app, @Pgallon311?
15-04-2024 05:37 PM
I did that earlier and it was still showing the data for the main account correct;y but the second account just as the amount for the start of the month. Right now the Appmisnt loading data - it’s often quite flaky, but in the browser I’m getting the same thing.
I was hoping it would update in the end as I don’t have time to sit on a support call.
15-04-2024 06:38 PM
Hi @Pgallon311,
If you continue to see the same issue in both the app and online, I'd recommend contacting Technical Support on 150 so they can get a ticket raised for you.
If the issue only started this morning, it's worth leaving it for 24 hours or so to rule out a temporary glitch.
16-04-2024 01:31 PM
Thank you I am doing that now. The guy is apparently having to enter it manually as he can see it going out but has not arrived due to “technical issues”.
21-04-2024 07:27 AM
I am having this exact problem. I gifted data from my SIM to another in the same account (I do this every month), my data has reduced by 5mb but the other SIM has not increased.
Was this issue sorted?
21-04-2024 07:44 AM
Yes -I had to call them on 150 and they did it manually. Said it was a “technical problem” so I wonder if they’ve got a bug and it’s done it to lots of people.
