06-07-2022 12:16 PM
Hi, I live in a flat with a 4g phone. I don't watch TV, just a little you tube and the odd prime video. Thinking cancelling my broadband and just tethering from my iPhone 11 Pro for the odd time I watch a movie or you tube on the bigger screen. Will this work OK? I noticed some providers advertise unlimited tethering, but can't find this on EE, is it limited? If so how much a month data a month to tethering is aloud? About to buy an EE sim only plan and switch from my old provider with dreadful inside coverage here in my flat!
06-07-2022 12:21 PM
EE allows you to use your tethering as much as your allowance allows, you're fine
06-07-2022 12:21 PM
06-07-2022 12:57 PM
@AJW11 : On an unlimited plan you may hotspot or use yourself up to the FUP of 600GB of your data per month.
