02-05-2024 08:35 PM
Currently in Latvia and I have roaming feel at home type contract since mines started way before the new changes. Anyway, since I landed, I have turned off my phone, turned it on, turned roaming on. But if I use my phone, every 30mins ish the signal completely disappears and so does the mobile data. And then after about 10 seconds it comes back. This keeps happening as I am using my phone. Also the mobile data stays at 3G. I am located in the city and last time I was here a week ago and everything was working fine.
I have turned off and on my phone, off and on the roaming and mobile data etc. but nothing has helped the problem
02-05-2024 08:38 PM - edited 02-05-2024 08:39 PM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
02-05-2024 08:44 PM
@Andreys1 If everything was fine a week ago and you’ve not changed anything then it sounds like a local network issue.
02-05-2024 08:56 PM
There's no menu option in your phone to enable roaming, it's an account setting that only CS have access to - I suspect you're confused with the "data roaming" option which just allows the use of mobile data whilst already roaming.
As already mentioned, if you have previously connected to foreign networks and not explicitly requested it removed, then it will still be active. If restarting your phone hasn't resolved, try manually selecting each local network in turn.
