02-05-2024 08:11 PM
I have no network coverage in Dubai, I need to use my uk number? Please help
02-05-2024 08:15 PM
@Irhu1 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
