23-06-2022 04:04 PM
Hello there,
I bought a Fairphone with a new SIM on a plan last week but the mobile data don't appear to work. I've tried setting up a new APN with the instruction as found here on the forum, but to no avail. There is also an eSIM in the phone, but I have disabled it.
Any suggestions what to do next?
24-06-2022 09:58 AM
Problem solved. It turned out to be an entirely different problem. My account was suspended because an initial payment had not gone through.
23-06-2022 04:31 PM
Hi @AndyH12
Tried these settings?
https://forum.fairphone.com/t/mms-not-sending-phone-coop/32548
23-06-2022 05:37 PM
Hi Northerner,
None of those links are working here...
I've done a reset on the mobile network and wifi and set up a new APN using the details in this forum, but that hasn't worked.
I did notice that I am able to connect to 3G (though the internet does not work), but it won't connect to LTE....
23-06-2022 06:21 PM
Update: also the same problem on my old phone. I'm apparently also unable to send texts so it might not just be a data problem. Unless someone has any other suggestions, I'll go back to the shop tomorrow and change the SIM for a new one.
24-06-2022 08:12 AM
Hi @AndyH12
Let us know how you get on in store, it would be great to know how you get this sorted.
24-06-2022 09:58 AM
24-06-2022 10:01 AM
