03-09-2023 09:45 PM
03-09-2023 10:24 PM
Hey there if you text SPENDCAP to 150 it will tell you what to do or you can see below
You can text the following codes to 150 for free to manage your spend caps:
ADD SPEND CAP
CHANGE SPEND CAP
PAUSE SPEND CAP
REMOVE SPEND CAP
03-09-2023 10:24 PM
ADD SPEND CAP
CHANGE SPEND CAP
PAUSE SPEND CAP
REMOVE SPEND CAP
