hello
iidjscottybxxz
im abit confused with the LOGIN info i want to use my own router i found my broadband username its the password info im getting abit confused with i need help and i want to know I'm upgrading to gfast on the 11th of august i know you will get a gfast modem but can i use enough router with that gfast modem or will i have to use my ee router? thank you
In Home Broadband settings you'll find almost everything you need to set up your own router incl. how to work out the pwd. What's missing for Fibre is:
  • VLAN ID = 101
You will not be getting a G.Fast Modem. You will be getting an integrated G.Fast modem router, the EE Smart Router. You may use that on its own or you may replace it by any generic G.Fast modem router, e.g. the ASUS DSL-AC88U.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
  • VLAN ID = 101
i have the new router will that support gfast or will they send me enough one but i do have a asus dsl ac88u so i could use that ?
If EE sent you a new router with your order for G.Fast BB then it must be for G.Fast. Is it the white EE Smart Router?
AS I said earlier you may use an ASUS DSL-AC88U in its place.
iidjscottybxxz
yes it looks like this is what i got when i got my FTTC does this router support gfasts-l960.jpg
Yes!
