30-07-2023 10:34 AM
unusually, the broadband connection is on and off, flashing amber and then eventually red. I phoned EE who did tests and said it kept "dropping off" and said an engineer was needed. The landline is okay so why would I need an engineer? What would the engineer do exactly?
30-07-2023 11:44 AM
An eng. might be able to trace a fault back the BB cab. or even the exchange. You say the the landline is OK but you sure there's absolutely no background noise between the convo.
31-07-2023 12:19 AM
thanks for reply. On Sunday during the day it managed to connect for one minute. It is now after midnight so I thought I would try and connect and see what happens. It has now been connected for 15 minutes, so it seems something is going on during the daytime with EE broadband.
I will see what happens tomorrow, Monday, during the day, and if there is still a problem I'll follow your instructions above.
What do you mean by 'noise between the convo' - If you mean any noise on the landline, there's always a slight crackle, but as I've said above, it has now been connected for 15 mins almost 20 now, so something is going on during daytime.
31-07-2023 12:23 AM
What's going on with my EE BB is that it works all day & night. So the issue lies with your specific line.
Crackle is not good! Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
31-07-2023 08:07 AM
Thank you for the further info. Connected at the moment for over 40 mins with no cutting out, but for now thanks for the detailed reply
