Broadband keeps disconnecting
debus68
Hello there, Our Wi-Fi keeps disconnecting and randomly going down to 34 mbps from anywhere in the range of 64-75mbps. As 34mbps is below our stay fast guarantee of 50mbps and we very often see this I don't think our broadband is doing what it should be doing. We disconnect at least once every day sometimes every 2 days, it seems to be very random and also the network going down to 34mbps is also very random as it doesn't happen every time. I don't think we should have to put up this bearing in mind how expensive our package is compared to what we get and how inconsistent it is.
27 REPLIES 27
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
debus68
Hi there, thank you for the fast response.
debus68
https://www.thinkbroadband.com/speedtest/1714085448431566755
The wifi is currently at normal speeds though, if you need screenshots of the 34 mpbs when it randomly decides to drop I have multiple speed tests saved from the speed test app dating all the way back from when we were on BT.
Well, you're getting 68 Meg at present which is in line with expectations & the speedtest.
Is that speedtest over WiFi or Ethernet?
I'd only be interested in seeing the router stats at the time the speed drops.
debus68
Ethernet, connected straight to the hub via the first port
debus68
Hi, the internet has just gone off 3 times in the space of about 10 minutes, it is now back down to 35 mbps. I will attach all the same images as last night but now with the low speed which is below our stay fast guarantee.
debus68
Yes, you're right ! Your raw BB sync speed has plummeted to 35 Meg.
Do you have a landline phone?
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
debus68
that’s whats behind the 2 clips when you take off the bottom half of the faceplate
