23-12-2023 10:25 AM
My WiFi has been down for two days and I’m not sure what to do about it
23-12-2023 11:11 AM
Hi @Chloemd02
Your home fixed line internet is down or WiFi from the router?
Have you tried restarting your router.
23-12-2023 11:18 AM
@Chloemd02 What WiFi service do you have?
What router do you have and what lights are showing? Have you tried turning it off for a minute or two and trying again?
Have you looked at the contact us page, just follow the links and give customer services a call.
23-12-2023 11:31 AM
Like you can connect to the internet but it doesn’t work but the router is still on the colour it’s ment to be on
23-12-2023 11:32 AM
EE, it’s letting us connect but it’s not working , it’s on the aqua colour it says it’s ment to be on it wen
23-12-2023 11:32 AM
It went off yesterday
23-12-2023 11:44 AM
If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
23-12-2023 11:46 AM
I’m not with bt I’m with EE
23-12-2023 11:49 AM
No, but it is Openreach, part of the BT Group, that controls the BB lines & BT will report on the status of all OR lines.
