09-02-2024 09:38 PM
Has EE been down today? We have been unable to connect our phones and other devices to wifi all day. Also our 4G has only just started working. Just wondering if it is a problem with EE or the router.
09-02-2024 09:50 PM
@Coz21 Wi-Fi is signal from your router and has nothing to do with a cellular reception on your device that are two different connection types.
Did you try a wired connection to the router ? Or perhaps restarting the router? What colour lights were on the router? And is your broadband with EE ?
Did you check to see if there was a mast issue in your area with THIS and clicking the check status tab ?
09-02-2024 11:05 PM
I turned the router off and back on and made sure all the wires were in properly. All the lights were on in their usual colour. Broadband is with EE. On the iphone and ipad, it says 'weak security' in wifi settings. Does that mean it's a problem with the router? How can I solve the problem? Would it be easier to get a new router? It's not the one that came with EE, it's a TP Link one I bought but we've had it years and not had a problem until now.
09-02-2024 11:13 PM
Is this for mobile BB or fixed Home BB? You said 4G in your OP so I assume mobile.
Set its WiFi security to like :
Security |
WPA
WPA Mode |
WPA2
Cipher Suite |
AES
for both the 2.4 & 5 GHz bands.
09-02-2024 11:22 PM
It's fixed home broadband. But we've had issues with 4g on our phones aswell. The 4g hasn't been great dor the past year but it's been terrible today. Managed to get one bar on this evening to do certain things online.
09-02-2024 11:23 PM
Where do I put those settings?
09-02-2024 11:31 PM
@Coz21 : Tell me which router you have?
09-02-2024 11:38 PM
TP Link AC1600 wireless gigabit VDSL/ADSL modem router Archer VR600
09-02-2024 11:42 PM
I wouldn't know that 1. Login to it & find the WiFi Settings page. Fit to what I told you or post a pix of it & I'll guide you.
10-02-2024 01:17 AM
I've installed the TP Link Tether app which I didn't have before. I set it up with my email address and chose a password. I put my phone on wifi and it found the router. I selected the router and it asked for the Log in password. What do I put for this? I tried putting the password I created after installing the app but it says it's the wrong password
