21-10-2023 09:14 AM
Sorry if this has been covered previously but I can find any information or help.
I've recently moved to EE and on the Full Fibre 900 which is brilliant.
The issue I have is that I'm not using the EE supplied Smart Hub as I have an extensive Asus Mesh network in place. The network is all sorted and really good but as I'm not using the EE Smart Hub my digital home phone can't be plug in or link via the adapter (which I also have).
Any ideas on how I can get my digital home phone service connected without using the EE Smart Hub.
I have tried connecting the EE Smart Hub to my Asus router vis ethernet but that did not work. I did not look at chaging any settings when I did this so maybe that is the issue.
Ideally I do not use the EE Smart Hub as a bridge as it big and bulky.
Any help are advice would be really appreciated.
21-10-2023 12:22 PM
Welcome to the community. 🙂
Obviously as an EE employee, I'd recommend using the equipment we've supplied, but understand that you don't want to.
We have some very knowledgeable users who, I'm sure, will be along to try and help you with this.
21-10-2023 11:34 PM
For DV you must use the EE SH supplied. It has a port for DECT connection.
It might be possible with the EE SH as the main router with the Asus as a WAP off it.
