24-01-2024 04:42 PM
After getting fibre installed I have had problems with the home hub repeatedly dropping my ethernet connection:
This is just today's events
24-01-2024 05:08 PM
@SeymourC what do you have connected to that port?
Have you tried changing cable or moving to another port?
24-01-2024 05:35 PM
A PC, and it does the same for other ports and cables.
24-01-2024 05:40 PM
Is it going into hibernation ?
Is it a direct connection or does it go through a switch or Home Plugs?
Does it report the same when the PC is not connected?
24-01-2024 06:09 PM
Shouldn't be, it's during active usage, direct connection and not tested with no connections as, well, I need to use it and can't sit with it unplugged just to see.
24-01-2024 06:16 PM
@SeymourC suggest you give the Broadband Care Team a call, not much I as a fellow customer can suggest at this time.
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
26-01-2024 11:57 AM
It's possible the NIC of your PC is actually failing or having some issue which is dropping the connection briefly. Is this a Windows PC or Server? Checked Event Log for issues pertaining to the network interface?
Just seems odd it is dropping connection on all 4 ports of hub (possible hub is faulty). You say you have changed cables and all that.
