07-11-2023 09:28 AM
07-11-2023 11:50 AM
Hi @Tricia173
Welcome to the community.
WiFi calling allows you to use the signal from your broadband to make calls. It's designed to keep you connected if the phone signal isn't strong. There's a setting in your phone settings to turn it off, if you want to.
Using WiFi Calling | Mobile Help | EE
07-11-2023 11:50 AM
Hi @Tricia173
