5G No connection
EG1511
Hi
I have 2 iPhones one iPhone 12 which works flawlessly with 5G with EE.
I then proceeded to put it into my iPhone 14 pro max (the SIM) and then it says 5G but with no internet connection.
has anyone had this issue before and know how to resolve this?
thanks
EssexBoyEE
Check the APN Settings under the Mobile Network Setting are correct for EE, is the iPhone 14 locked to another Network or was previously used on another Network ?
I’ve just about managed playing with it.
I had a Vodafone PAYG setup in one of the settings (can’t remember).
But thank you for the reply!
